HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Using hybrid concurrent constraint programming to model dynamic biological systems
Alexander Bockmayr 1 Arnaud Courtois 1
1 MODBIO - Computational models in molecular biology
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Systems biology is a new area in biology that aims at achieving a systems-level understanding of biological systems. While current genome projects provide a huge amount of data on genes or proteins, lots of research is still necessary to understand how the different parts of a biological system interact in order to perform complex biological functions. Computational models that help to analyze, explain or predict the behavior of biological systems play a crucial role in systems biology. The goal of this paper is to show that hybrid concurrent constraint programming (Gupta/Jagadeesan/Saraswat 98) may be a promising alternative to existing modeling approaches in systems biology. Hybrid cc is a declarative compositional programming language with a well-defined semantics. It allows one to model and simulate the dynamics of hybrid systems, which exhibit both discrete and continuous change. We show that Hybrid cc can be used naturally to model a variety of biological phenomena, such as reaching thresholds, kinetics, gene interaction or biological pathways.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00100783
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:50:59 PM
Last modification on : Friday, February 4, 2022 - 3:30:13 AM
Identifiers
  • HAL Id : inria-00100783, version 1
Collections
Citation
Alexander Bockmayr, Arnaud Courtois. Using hybrid concurrent constraint programming to model dynamic biological systems. 18th International Conference on Logic programming - ICLP'02, 2002, Copenhagen, Denmark, pp.85-99. ⟨inria-00100783⟩
Share
Metrics
Record views
58
