A Modal Linear Logic for Distribution and Mobility - extended abstract - - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
We present a multi-modal, first order, intuitionistic linear logic with locations, called DMLL. It is resource-sensitive and takes into account the notions of location and mobility of formulae (seen as resources) through the introduction of three modalities. We define a sequent calculus for which cut-elimination property is proved, a based-on resource semantic model and thus we prove the soundness and completeness of the calculus. Then, we discuss an extension of DMLL with quantifications over locations, called full-DMLL, and propose, from an appropriate subset, a new distributed process calculus with modalities. The relationships between computations and proof search in such logics will be studied and illustrated in some examples.
Fichier non déposé
inria-00100792 , version 1 (26-09-2006)
  • HAL Id : inria-00100792 , version 1
Nicolas Biri, Didier Galmiche. A Modal Linear Logic for Distribution and Mobility - extended abstract -. Workshop on Linear Logic - FLOC'02, 2002, Copenhagen, Danemark, 6 p. ⟨inria-00100792⟩
75 Consultations
0 Téléchargements
