HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
An Original Multi-Scale Algorithm to Binarize Images
Salvatore Tabbone 1 Laurent Wendling 1
1 QGAR - Querying Graphics through Analysis and Recognition
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : An original approach to binarize gray level images is proposed. A multi-scale algorithm based on a statistical test of homogeneity decides if a region belongs to the background or not. At each iteration the image is smoothed with a nonlinear filter in order to remove the noise. Stable regions in scale space are used to automatically find a threshold from the intensity histogram.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00100844
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:52:23 PM
Last modification on : Friday, February 4, 2022 - 3:11:06 AM
Identifiers
  • HAL Id : inria-00100844, version 1
Collections
Citation
Salvatore Tabbone, Laurent Wendling. An Original Multi-Scale Algorithm to Binarize Images. 16th International Conference on Pattern Recognition - ICPR'2002, 2002, Québec City, Canada, 17 p. ⟨inria-00100844⟩
Share
Metrics
Record views
33
