Partially complemented representations of digraphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2002
A complementation operation on a vertex of a digraph changes all outgoing arcs into non-arcs, and outgoing non-arcs into arcs. This defines an equivalence relation where two digraphs are equivalent if one can be obtained from the other by a sequence of such operations. We show that given an adjacency-list representation of a digraph G, many fundamental graph algorithms can be carried out on any member G' of G's equivalence class in O(n+m) time, where m is the number of arcs in G, not the number of arcs in G' . This may have advantages when G' is much larger than G. We use this to generalize to digraphs a simple O(n + m log n) algorithm of McConnell and Spinrad for finding the modular decomposition of undirected graphs. A key step is finding the strongly-connected components of a digraph F in G's equivalence class, where F may have ~(m log n) arcs.
514.pdf (184.23 Ko) Télécharger le fichier
inria-00100846 , version 1 (26-11-2009)
Elias Dahlhaus, Jens Gustedt, Ross M. Mcconnell. Partially complemented representations of digraphs. Discrete Mathematics and Theoretical Computer Science, 2002, Vol. 5, pp.147-168. ⟨10.46298/dmtcs.303⟩. ⟨inria-00100846⟩
109 Consultations
868 Téléchargements
