Cross-learning in Analytic Word Recognition Without Segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal on Document Analysis and Recognition Année : 2002
Christophe Choisy
  • Fonction : Auteur
  • PersonId : 836386
Abdel Belaïd
  • Fonction : Auteur
  • PersonId : 830137
In this paper a method for analytic handwritten word recognition based on causal Markov random fields is described. The word models are hmms where each state corresponds to a letter; each letter is modeled by a nshp (Markov field). The word models are built dynamically. Letter and word model training is made using baum algorithm where the parameters are re-estimated on the generated word global models. The segmentation is not necessary~: the system determines itself during training the best repartition of the information within the letter models. First experiments on two real databases of french check amount words give very encouraging results up to 86% for recognition.
Autre [cs.OH]
Fichier non déposé
inria-00100851 , version 1 (26-09-2006)
  • HAL Id : inria-00100851 , version 1
Christophe Choisy, Abdel Belaïd. Cross-learning in Analytic Word Recognition Without Segmentation. International Journal on Document Analysis and Recognition, 2002, 4 (4), pp.281-289. ⟨inria-00100851⟩
53 Consultations
0 Téléchargements
