HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Function Block Temporal Behaviour Modelling
Orazio Gurrieri Xavier Rebeuf 1 Françoise Simonot-Lion 1
1 TRIO - Real time and interoperability
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : For developing an efficient and dependable control system, it is necessary to construct a model, which can fully describe its control structure, function and behaviour. To ensure interoperability between components, function blocks should be used. Nevertheless, the behaviour is not enough precise for validating temporal interoperability. We propose to add to function blocks a behaviour model. It provides a runtime machine allowing simulation. || Pour développer des systèmes de contrôle performant et fiable, il est nécessaire de construire un modèle, qui peut décrire complétement son architecture en termes de fonctions ainsi que son comportement. La garantie de l'interopérabilité entre les composa
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00100868
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:52:33 PM
Last modification on : Friday, February 4, 2022 - 3:30:05 AM
Identifiers
  • HAL Id : inria-00100868, version 1
Collections
Citation
Orazio Gurrieri, Xavier Rebeuf, Françoise Simonot-Lion. Function Block Temporal Behaviour Modelling. 2002 IEEE International Symposium on Industrial Electronics - IEEE-ISIE'2002, 2002, L'Aquila/Italy, 8 p. ⟨inria-00100868⟩
Share
Metrics
Record views
39
