Signal Representation and Segmentation based on Multifractal Stationarity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2002
We present a new scheme for signal representation which is well suited for the study of multifractal features. In particular, our approach, which is based on the use of Weakly Self Affine functions, allows to segment a signal into parts which are ``multifractally homogeneous''. Furthermore, it opens the possibility of estimating non concave multifractal spectra, a valuable improvement for many practical applications such as Internet traffic modeling.
00100882.pdf (8.8 Mo) Télécharger le fichier
inria-00100882 , version 1 (13-11-2020)
Khalid Daoudi, Jacques Lévy Véhel. Signal Representation and Segmentation based on Multifractal Stationarity. Signal Processing, 2002, 82 (12), pp.2015-2024. ⟨10.1016/S0165-1684(02)00198-6⟩. ⟨inria-00100882⟩
107 Consultations
39 Téléchargements
