HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Ab initio phasing starting from low resolution
Abstract : A single set of structure factor magnitudes complete at low resolution plus information of a general type are sufficient to get initial phases for macromolecular crystals which allow one to see the molecular packing and an approximate envelope. Followed by a more careful analysis based on the same information, these ab initio phases can be extended so that the corresponding maps show secondary structure elements.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00101038
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:54:33 PM
Last modification on : Friday, February 4, 2022 - 3:22:13 AM
Identifiers
  • HAL Id : inria-00101038, version 1
Citation
Vladimir Y. Lunin, Natasha Lunina, A. Podjarny, Alexander Bockmayr, Alexandre Urzhumtsev. Ab initio phasing starting from low resolution. Zeitschrift für Kristallographie, De Gruyter, 2002, 217 (12), pp.668-685. ⟨inria-00101038⟩
Share
Metrics
Record views
39
