A bijection for triangulations of a polygon with interior points and multiple edges
Loopless triangulations of a polygon with $k$ vertices in $k+2n$ triangles (with interior points and possibly multiple edges) were enumerated by Mullin in 1965, using generating functions and calculations with the quadratic method. In this article we propose a simple bijective construction of Mullin's formula. The argument rests on conjugation of trees, a variation of the cycle lemma designed for planar maps. In the much easier case of loopless triangulations of the sphere ($k=3$), we recover and prove correct an unpublished construction of the second author. || Les triangulations sans boucles d'un polygone à $k$ côtés en $k+2n$ triangles (avec des points intérieurs et éventuellement des arêtes multiples) ont été énumérées par Mullin en 1965, à l'aide de séries génératrices et de la méthode quadratique. Dans cet
