Segmentation of Discrete Curves into Fuzzy Segments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
A new concept, fuzzy segments, is introduced which allows for flexible segmentation of discrete curves, so taking into account some noise in them. Relying on an arithmetic approach of discrete lines, it generalizes them, admitting that some points are missing. Thus, a larger class of objects is considered. A very efficient detection algorithm for fuzzy segments and its application to curve segmentation are presented.
Autre [cs.OH]
RR-4989.pdf (272.82 Ko) Télécharger le fichier
inria-00071589 , version 1 (23-05-2006)
  • HAL Id : inria-00071589 , version 1
Isabelle Debled-Rennesson, Jean-Luc Rémy, Jocelyne Rouyer-Degli. Segmentation of Discrete Curves into Fuzzy Segments. [Research Report] RR-4989, INRIA. 2003, pp.17. ⟨inria-00071589⟩
298 Consultations
316 Téléchargements
