Reports
Outermost ground termination - Extended version
Olivier Fissore 1 Isabelle Gnaedig 1 Hélène Kirchner 1
1 PROTHEO - Constraints, automatic deduction and software properties proofs
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : We propose a semi-automatic inductive process to prove termination of outermost rewriting on ground term algebras. The method is based on an abstraction mechanism, schematizing normalisation of subterms, and on narrowing, schematizing reductions on ground terms. The induction ordering is not needed a priori, but is a solution of constraints set along the proof. Our method applies in particular to systems that are non-terminating for the standard strategy nor even for the lazy strategy.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00101079
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:55:51 PM
Last modification on : Friday, February 26, 2021 - 3:28:05 PM
Identifiers
  • HAL Id : inria-00101079, version 1
Collections
Citation
Olivier Fissore, Isabelle Gnaedig, Hélène Kirchner. Outermost ground termination - Extended version. [Intern report] A02-R-493 || fissore02d, 2002, 38 p. ⟨inria-00101079⟩
Share
Metrics
Les métriques sont temporairement indisponibles
