A New Decomposition Technique for Solving Markov Decision Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
In this paper, we present a new tool for automatically solving Markov Decision Processes. Using a predefined partition o fthe MDP, a directed graph is built to decompose the global MDP into small local MDPs which are independently solved. An approximate solution for the global MDP is obtained using local solutions. Our approach has been tested on a mobile robotics application. It allows near-optimal solutions to be obtained in significantly reduced time. We also present preliminary results concerning a parallel implementation.
Fichier non déposé
inria-00101093 , version 1 (26-09-2006)
  • HAL Id : inria-00101093 , version 1
Pierre Laroche, Yann Boniface, René Schott. A New Decomposition Technique for Solving Markov Decision Processes. Symposium on Applied Computing - SAC'2001, 2001, Las Vegas, USA, 5 p. ⟨inria-00101093⟩
146 Consultations
0 Téléchargements
