Abstract : Assembly line balancing problems consist in partitioning the work necessary to assemble a number of products among different stations of an assembly line. We present a hybrid approach for solving such problems, which combines constraint programming and integer programming.
Alexander Bockmayr, Nicolai Pisaruk. Solving Assembly Line Balancing Problems by Combining IP and CP. Sixth Annual Workshop of the ERCIM Working Groupon Constraints, 2001, Prague, Czech Republic, 10 p. ⟨inria-00101101⟩
