Enhancing the Flexibility of Workflow Execution by Activity Anticipation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Business Process Integration and Management Année : 2006
This paper introduces an evolution to classical workflow model that allows more flexible execution of processes while retaining its simplicity. On the one hand it allows to describe processes in the same way that they are in design and engineering manuals. On the other hand it allows to control these processes in a way that is close to the way they are actually enacted. This evolution is based on the concept of anticipation, i.e. the weakening of strict sequential execution of activity sequences in workflows by allowing intermediate results to be used as preliminary input into succeeding activities. The concept can also be applied to provide rapid feedback to preceding activities, and for complex sub-processes. The architecture and implementation of a workflow execution engine prototype allowing anticipation is described
ijbpm.pdf (405.14 Ko) Télécharger le fichier
inria-00102552 , version 1 (02-10-2006)
  • HAL Id : inria-00102552 , version 1
Daniela Grigori, François Charoy, Claude Godart. Enhancing the Flexibility of Workflow Execution by Activity Anticipation. International Journal of Business Process Integration and Management, 2006, 1 (3), pp.143-155. ⟨inria-00102552⟩
96 Consultations
176 Téléchargements
