Polynomial differential equations compute all real computable functions on computable compact intervals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Complexity Année : 2007
In the last decade, the field of analog computation has experienced renewed interest. In particular, there have been several attempts to understand which relations exist between the many models of analog computation. Unfortunately, most models are not equivalent. It is known that Euler's Gamma function is computable according to computable analysis, while it cannot be generated by Shannon's General Purpose Analog Computer (GPAC). This example has often been used to argue that the GPAC is less powerful than digital computation. However, as we will demonstrate, when computability with GPACs is not restricted to real-time generation of functions, we obtain two equivalent models of analog computation. Using this approach, it has been shown recently that the Gamma function becomes computable by a GPAC \cite{Gra04}. Here we extend this result by showing that, in an appropriate framework, the GPAC and computable analysis are actually equivalent from the computability point of view, at least in compact intervals. Since GPACs are equivalent to systems of polynomial differential equations then we show that all real computable functions over compact intervals can be defined by such models.
JOC.pdf (236.85 Ko) Télécharger le fichier
inria-00102947 , version 1 (02-10-2006)
inria-00102947 , version 2 (04-12-2012)
  • HAL Id : inria-00102947 , version 2
Olivier Bournez, Manuel L. Campagnolo, Daniel S. Graça, Emmanuel Hainry. Polynomial differential equations compute all real computable functions on computable compact intervals. Journal of Complexity, 2007, 23 (3), pp.317--335. ⟨inria-00102947v2⟩
563 Consultations
590 Téléchargements
