HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
CAPSULE: Hardware-Assisted Parallel Execution of Component-Based Programs
Pierre Palatin 1 Yves Lhuillier 1 Olivier Temam 1
1 ALCHEMY - Architectures, Languages and Compilers to Harness the End of Moore Years
LRI - Laboratoire de Recherche en Informatique, UP11 - Université Paris-Sud - Paris 11, CNRS - Centre National de la Recherche Scientifique : UMR8623, Inria Saclay - Ile de France
Abstract : Since processor performance scalability will now mostly be achieved through thread-level parallelism, there is a strong incen- tive to parallelize a broad range of applications, including those with complex control flow and data structures. And writing par- allel programs is a notoriously difficult task. Beyond processor performance, the architect can help by facilitating the task of the programmer, especially by simplifying the model exposed to the programmer. In this article, among the many issues associated with writing par- allel programs, we focus on finding the appropriate parallelism granularity, and efficiently mapping tasks with complex control and data flow to threads. We propose to relieve the user and com- piler of both tasks by delegating the parallelization decision to the architecture at run-time, through a combination of hardware and software support and a tight dialogue between both. For the software support, we leverage an increasingly popular approach in software engineering, called component-based pro- gramming; the component contract assumes tight encapsulation of code and data for easy manipulation. Previous research works have shown that it is possible to augment components with the ability to split/spawn, providing a simple and fitting approach for programming parallel applications with complex control and data structures. However, such environments still require the program- mer to determine the appropriate granularity of parallelism, and spawning incurs significant overheads due to software run-time system management. For that purpose, we provide an environment with the ability to spawn conditionally depending on available hardware resources, and we delegate spawning decisions and actions to the architec- ture. This conditional spawning is implemented through frequent hardware resource probing by the program. This, in turn, enables rapid adaptation to varying workload conditions, data sets and hardware resources. Furthermore, thanks to appropriate com- bined hardware and compiler support, the probing has no signifi- cant overhead on program performance. We demonstrate this approach on an 8-context SMT, sev- eral non-trivial algorithms and re-engineered SPEC CINT2000 benchmarks, written using component syntax processed by our toolchain. We achieve speedups ranging from 1.1 to 3.0 on our test suite.
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/inria-00103184
Contributor : Pierre Palatin Connect in order to contact the contributor
Submitted on : Tuesday, October 3, 2006 - 4:16:40 PM
Last modification on : Friday, February 4, 2022 - 3:30:18 AM
Long-term archiving on: : Tuesday, April 6, 2010 - 5:52:16 PM
Identifiers
  • HAL Id : inria-00103184, version 1
Citation
Pierre Palatin, Yves Lhuillier, Olivier Temam. CAPSULE: Hardware-Assisted Parallel Execution of Component-Based Programs. MICRO-39, Dec 2006, Orlando, Florida, USA. ⟨inria-00103184⟩
Share
Metrics
Record views
154
Files downloads
218
