. Anonymous, Electronic Devices and Circuits, Engineering Sciences 154, Diode i-v Characteristics
1. Anonymous, SAFEIR Series, Bulletin 12120 rev
. Anonymous, Voltage regulator diodes
. Anonymous, Littelfuse varistors -Basic properties, Terminology and theory, Application Note AN9767, 1999.
V. Acary, B. Brogliato, and D. Goeleven, Higher order Moreau???s sweeping process: mathematical formulation and numerical simulation, Mathematical Programming, vol.43, issue.4
DOI : 10.1007/s10107-006-0041-0
K. Addi, S. Adly, B. Brogliato, and D. Goeleven, A method using the approach of Moreau and Panagiotopoulos for the mathematical formulation of non-regular circuits in electronics, to appear in Nonlinear Analysis, Series C : Hybrid Systems and Applications
S. Adly and D. Goeleven, A discretization theory for a class of semi-coercive unilateral problems, Numerische Mathematik, vol.87, issue.1, pp.1-34, 2000.
DOI : 10.1007/s002110000164
S. Adly and D. Goeleven, A stability theory for second-order nonsmooth dynamical systems with application to friction problems, Journal de Math??matiques Pures et Appliqu??es, vol.83, issue.1, pp.17-51, 2004.
DOI : 10.1016/S0021-7824(03)00071-0
URL : https://hal.archives-ouvertes.fr/hal-00068291
B. Brogliato, Some perspectives on the analysis and control of complementarity systems, IEEE Transactions on Automatic Control, vol.48, issue.6, pp.918-935, 2003.
DOI : 10.1109/TAC.2003.812777
B. Brogliato, Absolute Stability and the Lagrange-Dirichlet Theorem with Monotone Multivalued Mappings, Systems and Control Letters, pp.343-353, 2004.
B. Brogliato and D. Goeleven, The Krakovskii-LaSalle Invariance Principle for a Class of Unilateral Dynamical Systems, Mathematics of Control, Signals, and Systems, vol.17, issue.1, pp.57-76, 2005.
DOI : 10.1007/s00498-004-0145-0
M. K. Camlibel, W. P. Heemels, and H. Schumacher, On Linear Passive Complementarity Systems, European Journal of Control, vol.8, issue.3, pp.220-237, 2002.
DOI : 10.3166/ejc.8.220-237
M. K. Camlibel and J. M. Schumacher, Existence and uniqueness of solutions for a class of piecewise linear dynamical systems, Linear Algebra and its Applications, pp.351-352, 2002.
P. Denoyelle and V. Acary, The Non-Smooth Approach applied to simulating Integrated Circuits and Power Electronics. Evolution of electronic circuit simulators towards fast-SPICE performance, INRIA technical report RT-0321, 2006.
URL : https://hal.archives-ouvertes.fr/inria-00080839
F. Facchinei and J. Pang, Finite Dimensional Variational Inequalities and Complementarity Problems, 2003.
G. Fichera, Boundary Value Problems in Elasticity with Unilateral Constraints, In: Encyclopedia of Physics, 1972.
M. S. Gowda, Complementarity Problems over Locally Compact Cones, SIAM Journal on Control and Optimization, vol.27, issue.4, pp.836-841, 1989.
DOI : 10.1137/0327044
M. S. Gowda and I. Seidman, Generalized linear complementarity problems, Mathematical Programming, pp.329-340, 1990.
DOI : 10.1007/BF01585749
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.55.6415
D. Goeleven and B. Brogliato, Stability and Instability Matrices for Linear Evolution Variational Inequalities, IEEE Transactions on Automatic Control, vol.49, issue.4, pp.521-534, 2004.
DOI : 10.1109/TAC.2004.825654
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.330.1199
D. Goeleven, On the solvability of noncoercive linear variational inequalities in separable Hilbert spaces, Journal of Optimization Theory and Applications, vol.7, issue.3, pp.493-511, 1993.
DOI : 10.1007/BF00940555
D. Goeleven, G. E. Stavroulakis, and P. D. Panagiotopoulos, Solvability Theory for a Class of Hemivariational Inequalities Involving Copositive Plus Matrices, Applications in Robotics, Mathematical Programming, pp.75-441, 1996.
D. Goeleven, Noncoercive Variational Problems and Related Results, Pitman Research Notes in Mathematics Series, 1996.
D. Goeleven and J. Gwinner, On Semicoerciveness of a Class of Variational Inequalities, and an Application to a Friction Problem for von Karman Plates, Mathematische Nachrichten, vol.144, pp.89-109, 2002.
D. Goeleven, D. Motreanu, Y. Dumont, and M. Rochdi, Variational and Hemivariational Inequalities ? Theory, Methods and Applications, vol.1, 2003.
URL : https://hal.archives-ouvertes.fr/hal-01152816
D. Goeleven and D. Motreanu, Variational and Hemivariational Inequalities ? Theory Unilateral Problems and Unilateral Mechanics, Methods and Applications, vol.2, 2003.
D. Goeleven and D. Motreanu, On the Solvability of Variational Inequalities via Relaxed Complementarity Problems, Communications in Applied Analysis, vol.4, pp.533-546, 2000.
J. B. Hiriart-urruty and C. Lemaréchal, Fundamentals of Convex Analysis, 2001.
DOI : 10.1007/978-3-642-56468-0
W. P. Heemels, J. M. Schumacher, and S. Weiland, Linear complementarity systems, SIAM J. Applied Math, vol.60, pp.1234-1269, 2000.
URL : https://hal.archives-ouvertes.fr/hal-00834580
S. C. Hu and N. S. Papageorgiou, Handbook of Set-Valued Analysis, 1999.
D. Leenaerts and W. M. Van-bokhoven, Piecewise Linear Modeling and Analysis, 1998.
DOI : 10.1007/978-1-4757-6190-0
Y. Murakami, A Method for the Formulation and Solution of Circuits Composed of Switches and Linear RLC networks, IEEE Transactions on Circuits and Systems-I, vol.49, pp.315-327, 2002.
J. J. Moreau, La Notion du Surpotentiel et les Liaisons Unilatérales on Elastostatique, C.R. Acad. Sci. Paris, pp.167-954, 1968.
P. D. Panagiotopoulos, Inequality Problems in Mechanics and Applications, Convex and Nonconvex Energy Functions, 1985.
D. Pascali and S. Sburlan, Nonlinear Mappings of Monotone Type, Sijthoff and Noordhoff International Publishers, 1978.
J. Rauch, Discontinuous semilinear differential equations and multiple valued maps, Proc. Amer, pp.277-282, 1977.
DOI : 10.1090/S0002-9939-1977-0442453-6
R. T. Rockafellar, Convex Analysis, 1970.
DOI : 10.1515/9781400873173
D. E. Stewart, Reformulations of Measure Differential Inclusions and Their Closed Graph Property, Journal of Differential Equations, vol.175, issue.1, pp.108-129, 2001.
DOI : 10.1006/jdeq.2000.3968
I. Unité-de-recherche and . Rhône, Alpes 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4
I. Unité-de-recherche and . Lorraine, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche, 2004.
I. De-voluceau-rocquencourt, BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399
