Géométrie discrète en analyse d'images, Hermès, 1991. ,
« Impact du colza transgénique dans les systèmes de culture : étude du flux de gènes, pp.111-113, 1997. ,
A model of the influence of cropping system on gene escape from herbicide tolerant rapeseed crops to rape volunteers, Agric. Ecosyst. Environ, vol.83, pp.235-270, 2001. ,
« Spatial aspects of gene flow between rapeseed varieties and volunteers », Agronomy for sustainable development, pp.355-368, 2005. ,
Seed Limitation and the Dynamics of Feral Oilseed Rape on the M25 Motorway, Proc. of the Royal Society of London, pp.49-54, 1995. ,
DOI : 10.1098/rspb.1995.0008
« High diversity of oilseed rape pollen clouds over an agro-ecosystem indicates long-distance dispersal, Molecular Ecology, vol.14, pp.2269-228, 2005. ,
« Outcrossing frequencies and distribution of transgenic oilseed rape (Brassica napus L.) in the nearest neighbourhood, European journal of agronomy, vol.24, pp.26-34, 2006. ,
« A domain-specific language for patchy landscape modelling : The Brittany agricultural mosaic as a case study, Ecological Modelling, vol.194, pp.1-3, 2006. ,
« Pollen dispersal of oilseed rape : estimation of the dispersal function and effects of field dimension, Journal of Applied Ecology, vol.43, issue.1, pp.141-151, 2006. ,
Studying crop sequences with CarrotAge, a HMM-based data mining software, Ecological Modelling, vol.191, issue.1, pp.170-185, 2006. ,
DOI : 10.1016/j.ecolmodel.2005.08.031
URL : https://hal.archives-ouvertes.fr/hal-00017169
« Anticiper l'assolement pour mieux gérer les ressources en eau : comment valoriser les données d'occupation du sol ?, Ingénieries eau agriculture territoires, pp.42-55, 2005. ,
« Dispersal of arable crops by vehicles-a potential vector for the spread of genetically modified organisms, Proceedings of the 34th Annual Conference of the Ecological Society, p.276, 2004. ,
« Homogeneous rectangular tessellations », Advances in Applied Probability, vol.28, pp.993-1013, 1996. ,
« New case studies on the coexistence of GM and non-GM crops in European agriculture, Technical Report Series of the Joint Research Center of the European Commission, 2006. ,
« Persistence of oilseed rape (Brassica napus L.) outside of cultivated fields, Theor. appl. Genet, vol.102, pp.841-846, 2001. ,
« Pollen-mediated movement of herbicide resistance between commercial canola fields, Science, vol.296, pp.2386-2388, 2002. ,
Frequency and distance of pollen dispersal from transgenic oilseed rape (Brassica napus), Transgenic Research, vol.103, issue.6, pp.356-364, 1993. ,
DOI : 10.1007/BF01976177
Gene flow and agriculture : relevance for transgenic crops, de British Crop Protection Council Symposium Proceedings, pp.57-64, 1999. ,
« Pavage de l'espace suivant des contraintes de forme et de taille, 2005. ,
