The design and analysis of computer algorithms, 1974. ,
A Uniform Approach for the Fast Computation of Matrix-Type Pad?? Approximants, SIAM Journal on Matrix Analysis and Applications, vol.15, issue.3, pp.804-823, 1994. ,
DOI : 10.1137/S0895479892230031
Asymptotically fast solution of toeplitz and related systems of linear equations, Linear Algebra and its Applications, vol.34, pp.103-116, 1980. ,
DOI : 10.1016/0024-3795(80)90161-5
Strategies in Filtering in the Number Field Sieve, Lecture Notes in Comput. Sci, vol.1838, pp.209-231, 2000. ,
DOI : 10.1007/10722028_11
Factorization of a 512-Bit RSA Modulus, Preneel, pp.1-18, 2000. ,
DOI : 10.1007/3-540-45539-6_1
URL : https://hal.archives-ouvertes.fr/inria-00099117
Fast evaluation of logarithms in fields of characteristic two, IEEE Transactions on Information Theory, vol.30, issue.4, pp.587-594, 1984. ,
DOI : 10.1109/TIT.1984.1056941
Solving linear equations over GF(2): block Lanczos algorithm, Linear Algebra and its Applications, vol.192, pp.33-60, 1993. ,
DOI : 10.1016/0024-3795(93)90235-G
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
DOI : 10.2307/2153413
Modern Computer Algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
An Algorithm for Solving the Discrete Log Problem on Hyperelliptic Curves, Preneel, pp.19-34, 2000. ,
DOI : 10.1007/3-540-45539-6_2
URL : https://hal.archives-ouvertes.fr/inria-00512401
Algorithmique des courbes hyperelliptiques et applicationsàapplications`applicationsà la cryptologie, Thèse, ´ Ecole Polytechnique, 2000. ,
URL : https://hal.archives-ouvertes.fr/tel-00514848
GMP, the GNU multiple precision arithmetic library, 1996. ,
Fast algorithms for rational Hermite approximation and solution of Toeplitz systems, IEEE Transactions on Circuits and Systems, vol.26, issue.9, pp.750-755, 1979. ,
DOI : 10.1109/TCS.1979.1084696
Speeding up the division and square root of power series, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072675
Analysis of Coppersmith's block Wiedemann algorithm for the parallel solution of sparse linear systems, Math. Comp, vol.64, issue.210, pp.777-806, 1995. ,
Distributed Matrix-Free Solution of Large Sparse Linear Systems over Finite Fields, Algorithmica, vol.24, issue.3-4, pp.331-348, 1999. ,
DOI : 10.1007/PL00008266
On the complexity of computing determinants, Proc. Fifth Asian Symposium on Computer Mathematics of Lectures Notes Series on Computing, pp.13-27, 2001. ,
Solving Large Sparse Linear Systems Over Finite Fields, Advances in Cryptology ? CRYPTO '90, pp.109-133 ,
DOI : 10.1007/3-540-38424-3_8
Matrix-free linear system solving and applications to symbolic computations, 1995. ,
A Block Lanczos Algorithm for Finding Dependencies over GF(2), Advances in Cryptology ? EUROCRYPT '95, pp.106-120, 1995. ,
DOI : 10.1007/3-540-49264-X_9
Doubling algorithms for Toeplitz and related equations, ICASSP '80. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.954-959, 1980. ,
DOI : 10.1109/ICASSP.1980.1171074
Discrete logarithms in finite fields and their cryptographic significance, Advances in Cryptology ? EUROCRYPT '84, pp.224-314 ,
DOI : 10.1007/3-540-39757-4_20
Finding column dependencies in sparse matrices over F 2 by block Wiedemann Available from http, 1998. ,
Reduction of Huge, Sparse Matrices over Finite Fields Via Created Catastrophes, Experimental Mathematics, vol.32, issue.2, pp.89-94, 1992. ,
DOI : 10.1080/10586458.1992.10504250
Realizations of matrix sequences, 1972. ,
Fast computation of linear generators for matrix sequences and application to the block Wiedemann algorithm, Proceedings of the 2001 international symposium on Symbolic and algebraic computation , ISSAC '01, pp.323-331, 2001. ,
DOI : 10.1145/384101.384145
Computation of Discrete Logarithms in $$ \mathbb{F}_{2^{607} } $$, Advances in Cryptology ? ASIACRYPT '2001, pp.107-124, 2001. ,
DOI : 10.1007/3-540-45682-1_7
Discrete logarithms in GF(2 607 ) Email to the NMBRTHRY mailing list, 2002. ,
A study of Coppersmith's block Wiedemann algorithm using matrix polynomials, Research report LMC-IMAG, vol.975, 1997. ,
Further analysis of Coppersmith's block Wiedemann algorithm for the solution of sparse linear systems (extended abstract), Proceedings of the 1997 international symposium on Symbolic and algebraic computation , ISSAC '97, pp.32-39, 1997. ,
DOI : 10.1145/258726.258742
The solution of McCurley's discrete log challenge, Advances in Cryptology ? CRYPTO '98, pp.458-471, 1998. ,
DOI : 10.1007/BFb0055747
Solving sparse linear equations over finite fields, IEEE Transactions on Information Theory, vol.32, issue.1, pp.54-62, 1986. ,
DOI : 10.1109/TIT.1986.1057137
