Analysis of PSLQ, an integer relation finding algorithm, Math. Comp, vol.68, issue.225, pp.351-369, 1999. ,
Aspects of Hyperelliptic Curves over Large Prime Fields in Software Implementations, 2003. ,
DOI : 10.1007/978-3-540-28632-5_11
Number theory, Pure and Applied Mathematics, vol.20, 1966. ,
Moyenne arithmético-géométrique et périodes de courbes de genre 1 et 2, pp.36-64, 1988. ,
Elliptic Curves with a Given Number of Points, ANTS-VI, pp.117-131, 2004. ,
DOI : 10.1007/978-3-540-24847-7_8
Constructing elliptic curves of prescribed order, Thomas Stieltjes Institute for Mathematics, 2006. ,
A generalized arithmetic geometric mean, 2004. ,
Construction of Hyperelliptic Curves with CM and Its Application to Cryptosystems, LNCS, pp.259-273, 1976. ,
DOI : 10.1007/3-540-44448-3_20
A course in algorithmic algebraic number theory, Graduate Texts in Mathematics, vol.138, 1993. ,
Heuristics on class groups of number fields, Number theory, pp.33-62, 1983. ,
DOI : 10.1007/BF01199694
Action of Modular Correspondences around CM Points, LNCS, vol.2369, pp.234-243, 2002. ,
DOI : 10.1007/3-540-45455-1_19
Die Typen der Multiplikatorenringe elliptischer Funktionenk??rper, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.14, issue.1, pp.197-272, 1941. ,
DOI : 10.1007/BF02940746
Moyenne arithmético-géométrique, suites de Borchardt et applications, 2006. ,
Computing Igusa class polynomials via Chinese Remainder Theorem, 2004. ,
Fast genus 2 arithmetic based on Theta functions, Journal of Mathematical Cryptology, vol.1, issue.3, 2005. ,
DOI : 10.1515/JMC.2007.012
URL : https://hal.archives-ouvertes.fr/inria-00000625
Construction of secure random curves of genus 2 over prime fields On certain reduction problems concerning abelian surfaces, LNCS E. Z. Goren. Manuscripta math, vol.3027, issue.94, pp.239-25633, 1997. ,
Invariants de classe pour les corps CM quartiques, Annales de l???institut Fourier, vol.57, issue.2, 2004. ,
DOI : 10.5802/aif.2264
p-adic Numbers, p-adic Analysis and Zeta-Functions, Graduate Texts in Mathematics, vol.58, 1984. ,
DOI : 10.1007/978-1-4684-0047-2
Efficient Doubling on Genus Two Curves over Binary Fields, LNCS, vol.3357, pp.170-181, 2004. ,
DOI : 10.1007/978-3-540-30564-4_12
A quasi quadratic time algorithm for hyperelliptic curve point counting, The Ramanujan Journal, vol.2, issue.1 ,
DOI : 10.1007/s11139-006-0151-6
URL : https://hal.archives-ouvertes.fr/hal-00456401
Elliptic curves with complex multiplication. Posting to the Number Theory List, 2004. ,
Elliptic curves and formal groups In Lecture notes prepared in connection with the seminars held at the Summer Institute on Algebraic Geometry, 1964. ,
Algorithmes pour compter des points de courbes en petite caractéristique et en petit genre. Talk given in Rennes, 2002. ,
Utilisation de l'AGM pour le calcul de E(F2n ) Lettre adresséè a Gaudry et Harley, 2000. ,
Construction de courbes de genre 2 ?? partir de leurs modules, Effective methods in algebraic geometry ,
DOI : 10.1007/978-1-4612-0441-1_21
New explicit conditions of elliptic curve traces for FR-reduction, IEICE Trans. Fundamentals, issue.5, p.84, 2001. ,
Floating-point LLL revisited, Eurocrypt 2005, pp.215-233, 2005. ,
Hyperelliptic Curve Cryptosystems: Closing the Performance Gap to Elliptic Curves, 2003. ,
DOI : 10.1007/978-3-540-45238-6_28
The canonical lift of an ordinary elliptic curve over a finite field and its point counting, J. Ramanujan Math. Soc, vol.15, issue.4, pp.247-270, 2000. ,
Abelian Varieties with complex multiplication and modular functions, 1998. ,
DOI : 10.1515/9781400883943
NTL: A library for doing number theory ,
Kurven vom Geschlecht 2 und ihre Anwendung in Public-Key- Kryptosystemen, 1994. ,
fplll-1.2 a lattice LLL-reduction program, 2006. ,
Multi-Precision for LOCal-fields library, 2006. still under development, see http ,
Examples of genus two CM curves defined over the rationals, Mathematics of Computation, vol.68, issue.225, pp.307-320, 1999. ,
DOI : 10.1090/S0025-5718-99-01020-0
Computing zeta functions of curves over finite fields, 2003. ,
Konstruktion kryptographisch geeigneter Kurven mit komplexer Multiplikation, 2001. ,
