Sample Selection for Optimising Signature Enrolment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Richard Guest
  • Fonction : Auteur
  • PersonId : 835659
Mike Fairhurst
  • Fonction : Auteur
  • PersonId : 835660
Accurate and representative template construction is critical for the successful and robust operation of dynamic signature verification systems. This paper presents a comparison of enrolment sample selection strategies using a large database of donated signature samples. Enrolment strategies evaluated include several that are based on sample variance within standard signature performance features, together with a series of established reference methods used for purposes of “baseline” comparison. Sample selection enrolment strategies are tested on two representative commercial signature verification systems by assessing the rate of successful enrolment and verification. The results show that using a prediction method based on the measurement of variance within samples for selection increases the ability to successfully enrol. The investigation is thus important in helping to develop possible best practice for implementing effective enrolment procedures.
cr1014120765553.pdf (118.62 Ko) Télécharger le fichier
inria-00103781 , version 1 (05-10-2006)
  • HAL Id : inria-00103781 , version 1
Richard Guest, Mike Fairhurst. Sample Selection for Optimising Signature Enrolment. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France). ⟨inria-00103781⟩
Collections
IWFHR10
57 Consultations
85 Téléchargements
