Compiler-Based Approach for Exploiting Scratch-Pad in Presence of Irregular Array Access, Design, Automation and Test in Europe, p.3, 2001. ,
DOI : 10.1109/DATE.2005.97
URL : https://hal.archives-ouvertes.fr/hal-00181288
An optimal memory allocation scheme for scratch-pad-based embedded systems, ACM Transactions on Embedded Computing Systems, vol.1, issue.1, pp.6-26, 2002. ,
DOI : 10.1145/581888.581891
Scratchpad memory, Proceedings of the tenth international symposium on Hardware/software codesign , CODES '02, pp.73-78 ,
DOI : 10.1145/774789.774805
Heap Data Allocation to Scratch-Pad Memory in Embedded Systems, Journal of Embedded Computing, vol.1, issue.4, 2005. ,
Jose Manuel Mendias: An integrated hardware/software approach for run-time scratchpad management, DAC, vol.2004, pp.238-243 ,
Inter-program optimizations for conserving disk energy, Proceedings of the 2005 international symposium on Low power electronics and design , ISLPED '05, pp.335-338 ,
DOI : 10.1145/1077603.1077684
Register relabeling: A post-compilation technique for energy reduction, Workshop on Compilers and Operating Systems for Low Power, 2000. ,
Fujita: Power analysis and minimization techniques for embedded DSP software, IEEE Trans. Very Large Scale Integration, vol.5, pp.123-135, 1997. ,
Partitioning Variables across Register Windows to Reduce Spill Code in a Low-Power Processor, IEEE Transactions on Computers, vol.54, issue.8, pp.998-1012, 2005. ,
DOI : 10.1109/TC.2005.132
Bitwidth aware global register allocation, POPL, vol.2003, pp.85-96 ,
Data Compression Transformations for Dynamically Allocated Data Structures, CC, vol.2002, pp.14-28 ,
Santosh Pande: Storage assignment optimizations through variable coalescence for embedded processors, LCTES, vol.2003, pp.220-231 ,
