Complement to the implicitization of rational hypersurfaces by means of approximation complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2006
Recently, a method to compute the implicit equation of a parameterized hypersurface has been developed by the authors. We address here some questions related to this method : optimality of a degree estimate and determination of an extraneous factor that appears when the base points are not locally complete intersections. We then make a link with a resultant computation for the case of rational plane curves and for particular cases of space surfaces. As a consequence, we prove a conjecture of Busé, Cox and D'Andrea.
impl-bcj-3.pdf (191.78 Ko) Télécharger le fichier
inria-00104191 , version 1 (06-10-2006)
inria-00104191 , version 2 (13-09-2007)
  • HAL Id : inria-00104191 , version 1
Laurent Busé, Marc Chardin, Jean-Pierre Jouanolou. Complement to the implicitization of rational hypersurfaces by means of approximation complexes. 2006. ⟨inria-00104191v1⟩
308 Consultations
389 Téléchargements
