HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Scratchpad memories vs locked caches in hard real-time systems: a qualitative and quantitative comparison
Isabelle Puaut 1 Christophe Pais 1
1 CAPS - Compilation, parallel architectures and system
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Hard real-time tasks must meet their deadline in all situations, including in the worst-case one, otherwise the safety of the controlled system is jeopardized. In addition to this stringent demand for predictability, an increasing number of har real-time applications need to be fast as well. As a consequence, architectures with caches and/or on-chip static RAM (scratchpad memories) are of interest for such applications. As compared to unlocked caches which may raise predictability issues for some cache replacement policies [5], locked caches and software-controlled on-chip static RAM are more easily amenable to timing analysis. We propose in this paper an algorithm for off-line selection of the contents of on-chip memories. The algorithm supports two types of on-chip memories, namely locked caches and scratchpad memories. The contents of on-chip memory, although selected off-line, is changed at run-time, for the sake of scalability with respect to task size. The algorithm allows to make a quantitative comparison of worst-case performance of applications using these two kinds of on-chip memories. Experimental results show that the algorithm yields to good ratios of on-chip memory accesses on the worst-case execution path, with a tolerable reload overhead, for both types of on-chip memories. Furthermore, we highlight the circumstances under which one type of on-chip memory is more appropriate than the other depending of architectural parameters (cache block size) and application characteristics (basic block size).
Document type :
Reports
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00105010
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Tuesday, October 10, 2006 - 8:54:46 AM
Last modification on : Friday, February 4, 2022 - 3:18:39 AM
Long-term archiving on: : Tuesday, April 6, 2010 - 7:07:01 PM
Identifiers
  • HAL Id : inria-00105010, version 1
Citation
Isabelle Puaut, Christophe Pais. Scratchpad memories vs locked caches in hard real-time systems: a qualitative and quantitative comparison. [Research Report] PI 1818, 2006, pp.22. ⟨inria-00105010⟩
Share
Metrics
Record views
238
Files downloads
532
