Grammar-based codes: a new class of universal lossless source codes, IEEE Transactions on Information Theory, vol.46, issue.3, pp.737-754, 2000. ,
DOI : 10.1109/18.841160
A universal algorithm for sequential data compression, IEEE Transactions on Information Theory, vol.23, issue.3, pp.337-343, 1977. ,
DOI : 10.1109/TIT.1977.1055714
A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
DOI : 10.1002/j.1538-7305.1948.tb01338.x
Source coding with channel, distortion and complexity constraints, 1994. ,
Trellis source coding methods for low rates and short blocks, 2005. ,
Quantization, IEEE Transactions on Information Theory, vol.44, issue.6, pp.2325-2384, 1998. ,
DOI : 10.1109/18.720541
Practical Implementations of Arithmetic Coding, Image and Text compression, pp.85-112, 1992. ,
DOI : 10.1007/978-1-4615-3596-6_4
Efficient universal lossless data compression algorithms based on a greedy sequential grammar transform-part two: with context models, IEEE Transactions on Information Theory, vol.49, issue.11, pp.2874-2894, 2003. ,
DOI : 10.1109/TIT.2003.818411
A method for the construction of minimum redundancy codes, Proc. of the Inst, pp.1098-1101, 1952. ,
Optimal Computer Search Trees and Variable-Length Alphabetical Codes, SIAM Journal on Applied Mathematics, vol.21, issue.4, pp.514-532, 1971. ,
DOI : 10.1137/0121057
Joint source-channel coding with variable length codes, Proceedings of IEEE International Symposium on Information Theory, p.419, 1997. ,
DOI : 10.1109/ISIT.1997.613356
On the joint source-channel decoding of variable-length encoded sources: the BSC case, IEEE Transactions on Communications, vol.49, issue.12, pp.2052-2055, 2001. ,
DOI : 10.1109/26.974247
Joint source-channel LZ'77 coding, Data Compression Conference, 2003. Proceedings. DCC 2003, pp.273-282, 2003. ,
DOI : 10.1109/DCC.2003.1194018
Turbo codes for nonuniform memoryless sources over noisy channels, IEEE Commun. Lett, vol.6, pp.1253-1262, 2002. ,
Transmission of Nonuniform Memoryless Sources via Nonsystematic Turbo Codes, IEEE Transactions on Communications, vol.52, issue.8, pp.1344-1354, 2004. ,
DOI : 10.1109/TCOMM.2004.833026
Elements of Information Theory, 1991. ,
Suffix-constrained codes for progressive and robust data compression: self-multiplexed codes, Proc. Europ. Sign. Proc. Conf, 2004. ,
Reversible variable length codes, IEEE Transactions on Communications, vol.43, issue.2/3/4, pp.158-162, 1995. ,
DOI : 10.1109/26.380026
