Bayesian Analysis of Binary and Polychotomous Response Data, Journal of the American Statistical Association, vol.85, issue.422, pp.669-679, 1993. ,
DOI : 10.1016/0304-4076(84)90007-1
Variance modelling of longitudinal height data from a <i>Pinus radiata</i> progeny test, Canadian Journal of Forest Research, vol.30, issue.4, pp.645-654, 2000. ,
DOI : 10.1139/cjfr-30-4-645
Multi-Variate Probit Analysis, Biometrics, vol.26, issue.3, pp.535-546, 1970. ,
DOI : 10.2307/2529107
Hierarchical Modeling and Analysis for Spatial Data, Monographs on Statistics and Applied Probability 101. Boca Raton, FL: Chapman and Hall/CRC. xvii, 452 p, 2004. ,
DOI : 10.1201/9780203487808
Estimating the Mahalanobis Distance from Mixed Continuous and Discrete Data, Biometrics, vol.15, issue.2, pp.394-401, 2000. ,
DOI : 10.1111/j.0006-341X.2000.00394.x
Estimation des volumes et accroissements des peuplements forestiers avec référence particulière aux forêts tropicales, 1980. ,
Monte Carlo bayesian methods for discrete regression models and categorical time series, Bayesian Statistics Eds, vol.4, pp.577-586, 1993. ,
A Monte Carlo Approach to Nonnormal and Nonlinear State-Space Modeling, Journal of the American Statistical Association, vol.74, issue.418, pp.493-500, 1992. ,
DOI : 10.1080/01621459.1991.10475006
Properties of Prior and Posterior Distributions for Multivariate Categorical Response Data Models, Journal of Multivariate Analysis, vol.71, issue.2, pp.277-296, 1999. ,
DOI : 10.1006/jmva.1999.1846
Analysis of multivariate probit models, Biometrika, vol.85, issue.2, pp.347-361, 1998. ,
DOI : 10.1093/biomet/85.2.347
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.129.8876
Markov Chain Monte Carlo Convergence Diagnostics: A Comparative Review, Journal of the American Statistical Association, vol.90, issue.434, pp.883-904, 1996. ,
DOI : 10.1080/01621459.1996.10476956
A note on pseudolikelihood constructed from marginal densities, Biometrika, vol.91, issue.3, pp.729-737, 2004. ,
DOI : 10.1093/biomet/91.3.729
Multinomial Probit. The Theory and its Application to Demand Forecasting Economic Theory, Econometrics, and Mathematical Economics, 1979. ,
Pairwise likelihood approach to grouped continuous model and its extension, Statistics & Probability Letters, vol.75, issue.1, 2005. ,
DOI : 10.1016/j.spl.2005.05.017
Analysis of Longitudinal Data., Biometrics, vol.53, issue.2, 2003. ,
DOI : 10.2307/2533983
Spatial and temporal variations of soil respiration in a Eucalyptus plantation in Congo, Forest Ecology and Management, vol.202, issue.1-3, pp.149-160, 2006. ,
DOI : 10.1016/j.foreco.2004.07.019
Posterior Mode Estimation by Extended Kalman Filtering for Multivariate Dynamic Generalized Linear Models, Journal of the American Statistical Association, vol.82, issue.418, pp.501-509, 1992. ,
DOI : 10.1080/01621459.1988.10478582
Sampling-Based Approaches to Calculating Marginal Densities, Journal of the American Statistical Association, vol.4, issue.410, pp.398-409, 1990. ,
DOI : 10.1080/01621459.1986.10478240
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.512.2330
Bayesian Data Analysis, 2004. ,
Efficient Simulation from the Multivariate Normal and Student t Distributions Subject to Linear Constraints, Computing Science and Statistics: Proceedings of the Twenty Third Symposium on the Interface, pp.571-578, 1991. ,
Monte Carlo sampling methods using Markov chains and their applications, Biometrika, vol.57, issue.1, pp.97-109, 1970. ,
DOI : 10.1093/biomet/57.1.97
URL : http://biomet.oxfordjournals.org/cgi/content/short/57/1/97
Multivariate Models and Dependence Concepts. Monographs on Statistics and Applied Probability. 73. London: Chapman and Hall. xviii, 399 p, 1997. ,
Modeling Longitudinal Data with Ordinal Response by Varying Coefficients, Biometrics, vol.50, issue.3, pp.692-698, 2000. ,
DOI : 10.1111/j.0006-341X.2000.00692.x
Models and applications, Continuous Multivariate Distributions, vol.1, p.722, 2000. ,
Multivariate probit analysis: A neglected procedure in medical statistics, Statistics in Medicine, vol.42, issue.9, pp.1391-1403, 1991. ,
DOI : 10.1002/sim.4780100907
A Mixed-Effects Regression Model for Longitudinal Multivariate Ordinal Data, Biometrics, vol.43, issue.1, pp.261-268, 2006. ,
DOI : 10.1111/j.1541-0420.2005.00408.x
Applications of Item Response Theory to Practical Testing Problems, Erlbaum , Hillside, N.J, 1980. ,
Generalized, Linear and Mixed Models, Series in Probability and Statistics, 2001. ,
Bar-Hen. Prediction of Euclidean distances with discrete and continuous outcomes, Journal of Multivariate Ananlysis, 2005. ,
Bayesian Multivariate Logistic Regression, Biometrics, vol.42, issue.3, pp.739-746, 2004. ,
DOI : 10.1111/j.0006-341X.2004.00224.x
Longitudinal random effects models for genetic analysis of binary data with application to mastitis in dairy cattle, Genetics Selection Evolution, vol.35, issue.6, pp.457-468, 2003. ,
DOI : 10.1186/1297-9686-35-6-457
Model selection tests for nonlinear dynamic models, The Econometrics Journal, vol.34, issue.1, pp.1-10, 2002. ,
DOI : 10.1111/1468-0262.00152
Integrative modelling approach to assess the sustainability of the eucalyptus plantations in Congo, In: Connection between Forest Resources and Wood Quality: Modelling Approaches and Simulation Software.IUFRO Working Party S5.01.04, pp.611-621, 2002. ,
Age-related equations for above- and below-ground biomass of a Eucalyptus hybrid in Congo, Forest Ecology and Management, vol.205, issue.1-3, pp.199-214, 2005. ,
DOI : 10.1016/j.foreco.2004.10.006
Effect of initial fertilisation on biomass, nutrient content and nutrient-use efficiency of even-aged Norway spruce and Douglas-fir stands planted in the same ecological conditions. Trees Structure and Function, 2006. ,
Mixed effects models with bivariate and univariate association parameters for longitudinal bivariate binary response data, Biometrics, vol.55, issue.1, pp.85-93, 1999. ,
Generalized Linear Mixed Models with Varying Coefficients for Longitudinal Data, route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex, pp.8-15, 2004. ,
DOI : 10.1093/biostatistics/4.1.57
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
