Combining first and higher order rewrite systems with type assignment systems, Proc. of the 1st Int. Conf. on Typed Lambda Calculi and Applications, 1993. ,
DOI : 10.1007/BFb0037098
Modularity of termination and confluence in combinations of rewrite systems with ? ?, Proc. of the 20th Int. Colloq. on Automata, Languages, and Programming, 1993. ,
Modularity of strong normalization and confluence in the algebraic-??-cube, Proceedings Ninth Annual IEEE Symposium on Logic in Computer Science, 1994. ,
DOI : 10.1109/LICS.1994.316049
Lambda calculi with types, Handbook of logic in computer science, 1992. ,
DOI : 10.1017/cbo9781139032636
Termination and Confluence of Higher-Order Rewrite Systems, Proc. of the 11th Int. Conf. on Rewriting Techniques and Applications, 2000. ,
DOI : 10.1007/10721975_4
URL : https://hal.archives-ouvertes.fr/inria-00105556
The Calculus of Algebraic Constructions, Proc. of the 10th Int. Conf. on Rewriting Techniques and Applications, LNCS 1631, 1999. ,
DOI : 10.1007/3-540-48685-2_25
URL : https://hal.archives-ouvertes.fr/inria-00105545
Specification and proof in membership equational logic, Theoretical Computer Science, vol.236, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00099079
Combining algebra and higher-order types, [1988] Proceedings. Third Annual Information Symposium on Logic in Computer Science, 1988. ,
DOI : 10.1109/LICS.1988.5103
Polymorphic rewriting conserves algebraic strong normalization, Proc. of the 16th Int. Colloq. on Automata, Languages, and Programming, 1989. ,
DOI : 10.1016/0304-3975(91)90037-3
URL : http://doi.org/10.1016/0304-3975(91)90037-3
Polymorphic rewriting conserves algebraic strong normalization, Theoretical Computer Science, vol.83, issue.1, 1991. ,
Pattern matching with dependent types, Proc. of the 3rd Work. on Types for Proofs and Programs, 1992. ,
Constructions: A higher order proof system for mechanizing mathematics, Proc. of the 1985 European Conf. on Computer Algebra ,
DOI : 10.1007/3-540-15983-5_13
URL : https://hal.archives-ouvertes.fr/inria-00076155
Inductively defined types, Proc. of the 1988 Int. Conf. on Computer Logic ,
DOI : 10.1007/3-540-52335-9_47
The mathematical language Automath, its usage, and some of its extensions, Proc. of the Symp. on Automatic Demonstration, 1970. ,
Rewrite systems Handbook of Theoretical Computer Science, volume B: Formal Models and Semantics, 1990. ,
Theorem proving modulo, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-01199506
Proof normalization modulo, 1998. ,
DOI : 10.1007/3-540-48167-2_5
URL : https://hal.archives-ouvertes.fr/inria-00073143
On Girard's " Candidats de Réductibilité, 1990. ,
Codifying guarded definitions with recursion schemes, Proc. of the 5th Work. on Types for Proofs and Programs, 1994. ,
Structural recursive definitions in type theory, Proc. of the 25th Int. Colloq. on Automata, Languages, and Programming, 1998. ,
DOI : 10.1007/BFb0055070
Une extension de l'interprétation de Gödeì a l'analyse, et son applicationàapplicationà l'´ elimination des coupures dans l'analyse et la théorie des types, Proc. of the 2nd Scandinavian Logic Symp., volume 63 of Studies in Logic and the Foundations of Mathematics, 1971. ,
Interprétation fonctionelle etéliminationetélimination des coupures dans l'arithmetique d'ordre supérieur, 1972. ,
Proofs and Types, 1988. ,
On extensions of Gödel's System T. Master's thesis, 2000. ,
Executable higher-order algebraic specification languages, Proc. of the 6th Symp. on Logic in Computer Science, 1991. ,
Abstract data type systems, Theoretical Computer Science, vol.173, issue.2, 1997. ,
DOI : 10.1016/S0304-3975(96)00161-2
The higher-order recursive path ordering, Proceedings. 14th Symposium on Logic in Computer Science (Cat. No. PR00158), 1999. ,
DOI : 10.1109/LICS.1999.782635
Combinatory Reduction Systems, 1980. ,
Combinatory reduction systems: introduction and survey, Theoretical Computer Science, vol.121, issue.1-2, 1993. ,
DOI : 10.1016/0304-3975(93)90091-7
An Intuitionistic Theory of Types: Predicative Part, Proceedings of the 73' Logic Colloquium of Studies in Logic and the Foundations of Mathematics, 1975. ,
DOI : 10.1016/S0049-237X(08)71945-1
Intuitionistic type theory, Bibliopolis, 1984. ,
Higher-order rewrite systems and their confluence, Theoretical Computer Science, vol.192, issue.1, 1998. ,
DOI : 10.1016/S0304-3975(97)00143-6
URL : http://doi.org/10.1016/s0304-3975(97)00143-6
First-and second-order lambda calculi with recursive types, 1986. ,
Inductive Definition in Type Theory, 1987. ,
A logic programming language with lambda-abstraction, function variables, and simple unification, Proc. of the 1989 Int. Work. on Extensions of Logic Programming ,
Automates de formes normales et réductibilité inductive, 1997. ,
Higher-order critical pairs, [1991] Proceedings Sixth Annual IEEE Symposium on Logic in Computer Science, 1991. ,
DOI : 10.1109/LICS.1991.151658
Strong normalizability for the combined system of the typed lambda calculus and an arbitrary convergent term rewrite system, Proc. of the 1989 Int. Symp. on Symbolic and Algebraic Computation ,
A note on rewriting theory for uniqueness of iteration, Theory and Applications of Categories, vol.6, issue.4, 2000. ,
Solving Higher-Order Equations: From Logic to Programming, 1995. ,
DOI : 10.1007/978-1-4612-1778-7
Linear unification of higher-order patterns, Proc. of the 7th Int. Joint Conf. CAAP/FASE on Theory and Practice of Software Development, 1993. ,
DOI : 10.1007/3-540-56610-4_78
Verifying Process Algebra Proofs in Type Theory, Proc. of the Int. Work. on Semantics of Specification Languages, Workshops in Computing, 1993. ,
DOI : 10.1007/978-1-4471-3229-5_18
Combinators, Lambda-Terms and Proof Theory. D. Reidel, 1972. ,
DOI : 10.1007/978-94-010-2913-1
Intensional interpretations of functionals of finite type I, The Journal of Symbolic Logic, vol.91, issue.02, 1967. ,
DOI : 10.1007/BF01447860
Counterexamples to terminating for the direct sum of term rewriting systems, Information Processing Letters, vol.25, issue.3, 1986. ,
Termination proofs for higher-order rewrite systems, Proc. of the 1st Int. Work. on Higher-Order Algebra, Logic and Term Rewriting, 1993. ,
Confluence for Abstract and Higher-Order Rewriting, 1994. ,
Confluence and Normalization for Higher-Order Rewriting, 1996. ,
Une Théorie des Constructions Inductives, 1994. ,
