Abstract : In a previous work, we proved that an important part of the Calculus of Inductive Constructions (CIC), the basis of the Coq proof assistant, can be seen as a Calculus of Algebraic Constructions (CAC), an extension of the Calculus of Constructions with functions and predicates defined by higher-order rewrite rules. In this paper, we prove that almost all CIC can be seen as a CAC, and that it can be further extended with non-strictly positive types and inductive-recursive types together with non-free constructors and pattern-matching on defined symbols.
