The virtual mesh: A geometric abstraction for efficiently computing radiosity, ACM TOG, vol.20, issue.3, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00099297
Error control for radiosity, Proceedings of the eurographics workshop on Rendering techniques '96, p.153, 1996. ,
Global illumination of glossy environments using wavelets and importance, ACM TOG, vol.15, issue.1, 1996. ,
Clustering for glossy global illumination, ACM TOG, vol.16, issue.1, 1997. ,
Radiosity and Realistic Image Synthesis, 1993. ,
Restricted delaunay triangulations and normal cycle, SOCG conf. proc, 2003. ,
Intrinsic parameterizations of surface meshes, Proceedings of Eurographics, pp.209-218, 2002. ,
On the Design of CGAL, Softw. ? Pract. Exp, vol.30, issue.11, pp.1167-1202, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00073283
Hierarchical face clustering on polygonal surfaces, Symp. on Interactive 3D Graphics, 2001. ,
Efficient hierarchical refinement and clustering for radiosity in complex environments, Computer Graphics Forum, pp.Euro- graphics, 1996. ,
Hierarchical higher order face cluster radiosity for global illumination walkthroughs of complex non-diffuse environments, Computer Graphics Forum, 2003. ,
Modelling the Interaction of Light Between Diffuse Surfaces, Computer Graphics (ACM SIGGRAPH '84 Proceedings), pp.212-222, 1984. ,
Wavelet radiosity, Computer Graphics (Siggraph), 1993. ,
A rapid hierarchical radiosity algorithm, Computer Graphics (Siggraph), 1991. ,
Combining higher-order wavelets and discontinuity meshing: a compact representation for radiosity, Rendering Techniques 2004 (Eurographics Symposium on Rendering), 2004. ,
Least Squares Conformal Maps for Automatic Texture Atlas Generation, ACM TOG (SIGGRAPH conf. proc, pp.362-371, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00100754
Texture mapping progressive meshes, Computer Graphics (Siggraph), 2001. ,
Multichart geometry images, Symposium on Geometry Processing, 2003. ,
Hierarchcal radiosity on curved surfaces, Rendering Tech- niques, 1997. ,
Abf++ : Fast and robust angle based flattening, ACM Transactions on Graphics -In print, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00105689
A clustering algorithm for radiance calculation in general environments, Proceedings of the 6th Workshop on Rendering, Eurographics, 1995. ,
URL : https://hal.archives-ouvertes.fr/inria-00510120
A clustering algorithm for radiosity in complex environments, Proceedings of the 21st conf. on Computer Graphics and Interactive Techniques, 1994. ,
Bounded radiosity illumination on general surfaces and clusters, Comput. Graph. Forum, vol.16, issue.3, pp.309-318, 1997. ,
A hierarchical subdivision algorithm for stochastic radiosity methods, Rendering Techniques, pp.193-204, 1997. ,
Radiosity algorithms using higher order finite element methods, Proc. of SIGGRAPH-93: Computer Graphics, pp.209-212, 1993. ,
Face cluster radiosity, Rendering Techniques, Eurographics, 1999. ,
The Finite Element Method, 1989. ,
