Multilevel solvers for unstructured surface meshes, SIAM J. Sci. Comput ,
An adaptable surface parametrization method, 12th International Meshing Roundtable, 2003. ,
A supernodal approach to sparse partial pivoting, SIAM Journal on Matrix Analysis and Applications, vol.20, issue.3, pp.720-755, 1999. ,
Intrinsic parameterizations of surface meshes, Proceedings of Eurographics, pp.209-218, 2002. ,
Multiresolution Analysis of Arbitrary Meshes, Computer Graphics (SIGGRAPH Conf. Proc.). ACM, pp.173-182, 1995. ,
Surface parameterization: a tutorial and survey, Advances on Multiresolution in Geometric Modelling, 2003. ,
Computing conformal structures of surfaces, Communications in information and systems 2, pp.121-146, 2002. ,
MIPS: An efficient global parametrization method In Curve and Surface Design: Saint-Malo, pp.153-162, 1999. ,
MAPS: Multiresolution adaptive parameterization of surfaces, Computer Graphics (SIGGRAPH). ACM, pp.95-104, 1998. ,
Preconditioners for indefinite linear systems arising in surface parameterization, 2001. ,
Fast and memory efficient polygonal simplification, Proceedings of IEEE Visualization, pp.279-286, 1998. ,
Interactive texture mapping, SIGGRAPH 93 Conf. Proc, pp.27-34, 1993. ,
URL : https://hal.archives-ouvertes.fr/inria-00423776
Computing discrete minimal surfaces and their conjugates, Experimental Math, vol.2, p.15, 1993. ,
Consistent mesh parameterization, Computer Graphics (SIGGRAPH). ACM, pp.179-184, 2001. ,
Hierarchical least squares conformal maps, 11th Pacific Conference on Computer Graphics and Applications 2003 -PG'03, pp.263-270, 2003. ,
Signal-specialized parametrization, Eurographics Workshop on Rendering, pp.87-100, 2002. ,
Texture mapping progressive meshes, Computer Graphics (SIGGRAPH). ACM, pp.409-416, 2001. ,
Parameterization of faceted surfaces for meshing using angle based flattening, Engineering with Computers, vol.17, pp.326-337, 2001. ,
Seamster: Inconspicuous low-distortion texture seam layout, IEEE Visualization, 2002. ,
High-pass quantization for mesh encoding, Proceedings of the Eurographics/ACM SIGGRAPH symposium on Geometry processing. Eurographics Association, pp.42-51, 2003. ,
Deformation transfer for triangle meshes, ACM TOG (Proc.SIGGRAPH 04), pp.397-403, 2004. ,
A fast and simple stretch-minimizing mesh parameterization, Proc. Shape Modeling and Applications, pp.200-208, 2004. ,
