Lipschitz stability for the inverse Robin problem
We are concerned with an inverse problem arising in corrosion detection. We prove a Lipschitz stability estimate for a scalar Robin coefficient on an accessible portion of the boundary by electrostatic measurements performed on the accessible one.
