Abstract : This paper presents the formal verification of a compiler front-end that translates a subset of the C language into the Cminor intermediate language. The semantics of the source and target languages as well as the translation between them have been written in the specification language of the Coq proof assistant. The proof of observational semantic equivalence between the source and generated code has been machine-checked using Coq. An executable compiler was obtained by automatic extraction of executable Caml code from the Coq specification of the translator, combined with a certified compiler back-end generating PowerPC assembly code from Cminor, described in previous work.
https://hal.inria.fr/inria-00106401 Contributor : Sandrine BlazyConnect in order to contact the contributor Submitted on : Monday, October 16, 2006 - 10:14:34 AM Last modification on : Monday, February 21, 2022 - 3:38:08 PM Long-term archiving on: : Thursday, September 20, 2012 - 11:55:18 AM
