-resilient asynchronous computations, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.91-100, 1993. ,
DOI : 10.1145/167088.167119
URL : https://hal.archives-ouvertes.fr/hal-00896459
The Implication of the Borowsky-Gafni Simulation on the Set Consensus Hierarchy, 1993. ,
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
Unreliable failure detectors for reliable distributed systems, Journal of the ACM, vol.43, issue.2, pp.225-267, 1996. ,
DOI : 10.1145/226643.226647
More Choices Allow More Faults: Set Consensus Problems in Totally Asynchronous Systems, Information and Computation, vol.105, issue.1, pp.132-158, 1993. ,
DOI : 10.1006/inco.1993.1043
Reducing to 3W, Information Processing Letters, vol.76, issue.6, pp.293-298, 1998. ,
Fast Indulgent Consensus with Zero Degradation, Proc. 4th European Dependable Computing Conference Springer-Verlag LNCS #2485, pp.191-208, 2002. ,
DOI : 10.1007/3-540-36080-8_18
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.3492
(Almost) All Objects Are Universal in Message Passing Systems, Proc. 19th Symposium on Distributed Computing (DISC'05), pp.184-198, 2005. ,
DOI : 10.1007/11561927_15
URL : https://hal.archives-ouvertes.fr/hal-00154869
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
DOI : 10.1145/3149.214121
Non-blocking atomic commit in asynchronous distributed systems with failure detectors, Distributed Computing, pp.17-25, 2002. ,
DOI : 10.1007/s446-002-8027-4
The information structure of indulgent consensus, IEEE Transactions on Computers, vol.53, issue.4, pp.453-466, 2004. ,
DOI : 10.1109/TC.2004.1268403
Gamma-accurate Failure Detectors, Proc. 1Oth Workshop on Distributed Algorithms (WDAG'96), pp.269-286, 1996. ,
DOI : 10.1007/3-540-61769-8_18
Reliable Broadcast and Related Problems, Distributed Systems, pp.97-145, 1993. ,
Tight Bounds for k-Set Agreement with Limited Scope Accuracy Failure Detectors, Distributed Computing, pp.157-166, 2005. ,
Set Consensus using Arbitrary Objects, Proc. 13th ACM Symposium on Principles of Distributed Computing (PODC'94), A CM Press, pp.324-333, 1994. ,
DOI : 10.1145/197917.198119
The topological structure of asynchronous computability, Journal of the ACM, vol.46, issue.6, pp.858-923, 1999. ,
DOI : 10.1145/331524.331529
The part-time parliament, ACM Transactions on Computer Systems, vol.16, issue.2, pp.133-169, 1998. ,
DOI : 10.1145/279227.279229
Conditions on input vectors for consensus solvability in asynchronous distributed systems, Journal of the ACM, vol.50, issue.6, pp.922-954, 2003. ,
DOI : 10.1145/950620.950624
The combined power of conditions and failure detectors to solve asynchronous set agreement, Proceedings of the twenty-fourth annual ACM SIGACT-SIGOPS symposium on Principles of distributed computing , PODC '05, pp.179-188, 2005. ,
DOI : 10.1145/1073814.1073848
From 3W to : a Simple Bounded Quiescent Reliable broadcast-based Transformation, Journal of Parallel and Distributed Computing, 2007. ,
Irreducibility and Additivity of Set Agreement-oriented Failure Detector Classes (Extended Abstract), Proc. 25th ACM Symposium on Principles of Distributed Computing (PODC'06), pp.153-162, 2006. ,
Solving Consensus Using Chandra-Toueg's Unreliable Failure Detectors: a General Quorum-Based Approach, Proc. 13th Symposium on Distributed Computing (DISC'99), pp.49-63, 1999. ,
Unreliable Failure Detectors with Limited Scope Accuracy and an Application to Consensus, Proc. 19th Int'l Conference on Foundations of Software Technology and Theoretical Computer Science (FST&TCS'99) Springer Verlag LNCS #1738, pp.329-340, 1999. ,
DOI : 10.1007/3-540-46691-6_26
k-set agreement with limited accuracy failure detectors, Proceedings of the nineteenth annual ACM symposium on Principles of distributed computing , PODC '00, pp.143-152, 2000. ,
DOI : 10.1145/343477.343536
Leader-Based Consensus, Parallel Processing Letters, vol.11, issue.1, pp.95-107, 2001. ,
Failure Detectors and the Wait-free Hierarchy, Proc. 14th ACM Symposium on Principles of Distributed Computing (PODC'95), A CM Press, pp.100-109, 1995. ,
A short introduction to failure detectors for asynchronous distributed systems, ACM SIGACT News, vol.36, issue.1, pp.53-70, 2005. ,
DOI : 10.1145/1052796.1052806
-set agreement is impossible, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.1449-1483, 2000. ,
DOI : 10.1145/167088.167122
URL : https://hal.archives-ouvertes.fr/hal-00192526
Early Consensus in an Asynchronous System with a Weak Failure Detector, Distributed Computing, pp.149-157, 1997. ,
Structured derivations of consensus algorithms for failure detectors, Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.297-308, 1998. ,
DOI : 10.1145/277697.277755
