Index calculus for non-hyperelliptic curves of genus 3 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
We study an index calculus algorithm to solve the discrete logarithm problem (DLP) in degree~0 class groups of non-hyperelliptic curves of genus~3 over finite fields. We present a heuristic analysis of the algorithm which indicates that the DLP in degree~0 class groups of non-hyperelliptic curves of genus~3 can be solved in an expected time of soft-O(q). This heuristic result relies on one heuristic assumption which is studied experimentally. We also present experimental data which show that a variant of the algorithm is faster than the Rho method even for small group sizes, and we address practical limitations of the algorithm.
non-he-genus3.pdf (228.39 Ko) Télécharger le fichier
inria-00107290 , version 1 (17-10-2006)
inria-00107290 , version 2 (15-11-2007)
  • HAL Id : inria-00107290 , version 1
Claus Diem, Emmanuel Thomé. Index calculus for non-hyperelliptic curves of genus 3. 2006. ⟨inria-00107290v1⟩
201 Consultations
248 Téléchargements
