Equations of parametric surfaces with base points via syzygies, Journal of Symbolic Computation, vol.39, issue.1, pp.73-101, 2005. ,
DOI : 10.1016/j.jsc.2004.09.007
An Implicitization Algorithm for Rational Surfaces with no Base Points, Journal of Symbolic Computation, vol.31, issue.4, pp.357-365, 2001. ,
DOI : 10.1006/jsco.1999.0436
URL : http://doi.org/10.1006/jsco.1999.0436
IN THE PRESENCE OF BASE POINTS, Journal of Algebra and Its Applications, vol.02, issue.02, pp.189-214, 2003. ,
DOI : 10.1142/S0219498803000489
Inversion of parameterized hypersurfaces by means of subresultants, Proceedings of the 2004 international symposium on Symbolic and algebraic computation , ISSAC '04, pp.65-71, 2004. ,
DOI : 10.1145/1005285.1005297
Using projection operators in computer aided geometric design, Topics in Algebraic Geometry and Geometric Modeling, pp.321-342, 2003. ,
DOI : 10.1090/conm/334/05988
The <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-basis and implicitization of a rational parametric surface, Journal of Symbolic Computation, vol.39, issue.6, pp.689-706, 2005. ,
DOI : 10.1016/j.jsc.2005.01.003
Degree, multiplicity, and inversion formulas for rational surfaces using u-resultants, Computer Aided Geometric Design, vol.9, issue.2, pp.93-108, 1992. ,
DOI : 10.1016/0167-8396(92)90009-E
On the Validity of Implicitization by Moving Quadrics for Rational Surfaces with No Base Points, Journal of Symbolic Computation, vol.29, issue.3, pp.419-440, 2000. ,
DOI : 10.1006/jsco.1999.0325
Using algebraic geometry, Graduate Texts in Mathematics, vol.185, 1998. ,
DOI : 10.1007/978-1-4757-6911-1
Hybrid sparse resultant matrices for bivariate polynomials, Computer algebra J. Symbolic Comput, vol.33, issue.5, pp.587-608, 2001. ,
Implicitization of rational surfaces using toric varieties, Journal of Algebra, vol.303, issue.2 ,
DOI : 10.1016/j.jalgebra.2005.05.028
Multihomogeneous resultant formulae by means of complexes, International Symposium on Symbolic and Algebraic Computation (ISSAC'2002) (Lille), J. Symbolic Comput, pp.3-4, 2003. ,
DOI : 10.1016/S0747-7171(03)00086-5
Algebraic geometry. Graduate Texts in Mathematics, 1977. ,
Formes d'inertie et r??sultant: un formulaire, Advances in Mathematics, vol.126, issue.2, pp.119-250, 1997. ,
DOI : 10.1006/aima.1996.1609
URL : http://doi.org/10.1006/aima.1996.1609
Sylvester-resultants for bivariate polynomials with planar newton polygons, Proceedings of the 2004 international symposium on Symbolic and algebraic computation , ISSAC '04, pp.205-212, 2004. ,
DOI : 10.1145/1005285.1005316
Properness and inversion of rational parameterizations of surfaces, Appl. Algebra Engrg. Comm. Comput, vol.13, issue.1, pp.29-51, 2002. ,
Inversion of birational maps with Gröbner bases. Gröbner bases and applications, Soc. Lecture Note Ser, vol.251, pp.495-503, 1998. ,
Implicitization using moving curves and surfaces, Proceedings of the 22nd annual conference on Computer graphics and interactive techniques , SIGGRAPH '95, pp.301-308, 1995. ,
DOI : 10.1145/218380.218460
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.32.7968
Symbolic parametrization of curves, Journal of Symbolic Computation, vol.12, issue.6, pp.607-631, 1991. ,
DOI : 10.1016/S0747-7171(08)80144-7
Rational Parametrizations of Algebraic Curves using a Canonical Divisor, Journal of Symbolic Computation, vol.23, issue.2-3, pp.209-227, 1995. ,
DOI : 10.1006/jsco.1996.0084
Implicitizing rational surfaces with base points using the method of moving surfaces, Contemp. Math, vol.334, pp.151-168, 2003. ,
DOI : 10.1090/conm/334/05980
93, 06902 Sophia-Antipolis cedex, France. E-mail address: lbuse@sophia.inria.fr Departament d' ` Algebra i Geometria, INRIA, 2004. ,
