A subexponential algorithm for the discrete logarithm problem with applications to cryptography, 20th Annual Symposium on Foundations of Computer Science (sfcs 1979), pp.55-60, 1979. ,
DOI : 10.1109/SFCS.1979.2
The function field sieve, 1st Algorithmic Number Theory Symposium, pp.108-121, 1994. ,
DOI : 10.1007/3-540-58691-1_48
A subexponential algorithm for discrete logarithms over all finite fields, Mathematics of Computation, vol.61, issue.203, pp.1-15, 1993. ,
DOI : 10.1090/S0025-5718-1993-1225541-3
Algorithms for computations in Jacobians of C ab curve and their application to discrete-log-based public key cryptosystems, Proceedings of Conference on The Mathematics of Public Key Cryptography, pp.12-17, 1999. ,
Computing Logarithms in Finite Fields of Characteristic Two, SIAM Journal on Algebraic Discrete Methods, vol.5, issue.2, pp.276-285, 1984. ,
DOI : 10.1137/0605029
Strategies in Filtering in the Number Field Sieve, ANTS-IV 4th Algorithmic Number Theory Symposium, pp.209-231, 2000. ,
DOI : 10.1007/10722028_11
Factorization of a 512-Bit RSA Modulus, Advances in Cryptology ? EURO- CRYPT 2000 Proc. International Conference on the Theory and Application of Cryptographic Techniques, pp.1-18, 2000. ,
DOI : 10.1007/3-540-45539-6_1
URL : https://hal.archives-ouvertes.fr/inria-00099117
ZEN, a toolbox for fast computation in finite extensions over finite rings ,
Fast evaluation of logarithms in fields of characteristic two, IEEE Transactions on Information Theory, vol.30, issue.4, pp.587-594, 1984. ,
DOI : 10.1109/TIT.1984.1056941
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
DOI : 10.2307/2153413
On the reduction of composed relations from the number field sieve, 2nd Algorithmic Number Theory Symposium, pp.75-90, 1996. ,
DOI : 10.1007/3-540-61581-4_43
New directions in cryptography, IEEE Transactions on Information Theory, vol.22, issue.6, pp.644-654, 1976. ,
DOI : 10.1109/TIT.1976.1055638
NFS with Four Large Primes: An Explosive Experiment, Proc. 15th Annual International Cryptology Conference, pp.372-385, 1995. ,
DOI : 10.1007/3-540-44750-4_30
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.126.5323
A remark concerning m-divisibility and the discrete logarithm in the divisor class group of curves, Math. Comp, vol.62, issue.206, pp.865-874, 1994. ,
Arithmetic on superelliptic curves, Mathematics of Computation, vol.71, issue.237, 2001. ,
DOI : 10.1090/S0025-5718-00-01297-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.18.1706
Discrete Logarithms in $GF ( P )$ Using the Number Field Sieve, SIAM Journal on Discrete Mathematics, vol.6, issue.1, pp.124-138, 1993. ,
DOI : 10.1137/0406010
Massively Parallel Computation of Discrete Logarithms, Proc. 12th Annual International Cryptology Conference, pp.312-323, 1992. ,
DOI : 10.1007/3-540-48071-4_22
GMP, the GNU multiple precision arithmetic library, 1996. ,
Discrete logarithms in GF(2 n ) (521 bits) Email to the NMBRTHRY mailing list, 2001. ,
Discrete logarithms in GF(p) (120 decimal digits) Email to the NMBRTHRY mailing list, 2001. ,
Analysis of Coppersmith's block Wiedemann algorithm for the parallel solution of sparse linear systems, Math. Comp, vol.64, issue.210, pp.777-806, 1995. ,
Distributed Matrix-Free Solution of Large Sparse Linear Systems over Finite Fields, Algorithmica, vol.24, issue.3-4, pp.331-348, 1999. ,
DOI : 10.1007/PL00008266
Elliptic curve cryptosystems, Mathematics of Computation, vol.48, issue.177, pp.203-209, 1987. ,
DOI : 10.1090/S0025-5718-1987-0866109-5
Hyperelliptic cryptosystems, Journal of Cryptology, vol.2, issue.4, pp.139-150, 1989. ,
DOI : 10.1007/BF02252872
Solving Large Sparse Linear Systems Over Finite Fields, Advances in Cryptology ? CRYPTO '90 Proc. 10th Annual International Cryptology Conference, pp.109-133, 1990. ,
DOI : 10.1007/3-540-38424-3_8
Factoring with two large primes, Mathematics of Computation, vol.63, issue.208, pp.785-798, 1994. ,
DOI : 10.1090/S0025-5718-1994-1250773-9
Finite fields of Encyclopedia of mathematics and its applications, 1983. ,
Reducing elliptic curve logarithms to logarithms in a finite field, IEEE Transactions on Information Theory, vol.39, issue.5, pp.1639-1646, 1993. ,
DOI : 10.1109/18.259647
Elliptic curve public key cryptosystems, 1993. ,
DOI : 10.1007/978-1-4615-3198-2
A Block Lanczos Algorithm for Finding Dependencies over GF(2) ,
DOI : 10.1007/3-540-49264-X_9
A new efficient factorization algorithm for polynomials over small finite fields, Applicable Algebra in Engineering, Communication and Computing, vol.35, issue.2, pp.81-87, 1993. ,
DOI : 10.1007/BF01386831
Discrete logarithms in finite fields and their cryptographic significance, Advances in Cryptology ? EUROCRYPT '84, pp.224-314 ,
DOI : 10.1007/3-540-39757-4_20
Reduction of Huge, Sparse Matrices over Finite Fields Via Created Catastrophes, Experimental Mathematics, vol.32, issue.2, pp.89-94, 1992. ,
DOI : 10.1080/10586458.1992.10504250
Efficient signature generation by smart cards, Journal of Cryptology, vol.4, issue.3, pp.161-174, 1991. ,
DOI : 10.1007/BF00196725
URL : http://publikationen.ub.uni-frankfurt.de/files/4280/schnorr.pdf
Fast computation of linear generators for matrix sequences and application to the block Wiedemann algorithm, Proceedings of the 2001 international symposium on Symbolic and algebraic computation , ISSAC '01, pp.323-331, 2001. ,
DOI : 10.1145/384101.384145
Further analysis of Coppersmith's block Wiedemann algorithm for the solution of sparse linear systems (extended abstract), Proceedings of the 1997 international symposium on Symbolic and algebraic computation , ISSAC '97, pp.32-39, 1997. ,
DOI : 10.1145/258726.258742
A study of Coppersmith's block Wiedemann algorithm using matrix polynomials, Research report LMC-IMAG, vol.975, 1997. ,
The solution of McCurley's discrete log challenge, Proc. 18th Annual International Cryptology Conference, pp.458-471, 1998. ,
DOI : 10.1007/BFb0055747
Solving sparse linear equations over finite fields, IEEE Transactions on Information Theory, vol.32, issue.1, pp.54-62, 1986. ,
DOI : 10.1109/TIT.1986.1057137
