Environmental adaptation based on first order approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
In this paper, we propose an algorithm that compensates for both additive and convolutional noise. The goal of this method is to achieve an efficient environmental adaptation to realistic environments both in terms of computation time and memory. The algorithm described in this paper is an extension of an additive noise adaptation algorithm presented in [1]. Experimental results are given on a realistic database recorded in a car. This database is further filtered by a low pass filter to combine additive and channel noise. The proposed adaptation algorithm reduces the error rate by 75 % on this database, when compared to our baseline system without environmental adaptation.
Autre [cs.OH]
A01-R-227.pdf (48.16 Ko) Télécharger le fichier
inria-00107522 , version 1 (19-10-2006)
  • HAL Id : inria-00107522 , version 1
Christophe Cerisara, Luca Rigazio, Robert Boman, Jean-Claude Junqua. Environmental adaptation based on first order approximation. International Conference on Acoustics, Speech, and Signal Processing - ICASSP 2001, May 2001, Salt lake City, USA, 4 p. ⟨inria-00107522⟩
207 Consultations
129 Téléchargements
