Abstract : This paper explains how case-based problem solving can have benefit from a hierarchical organisation of problems based on a generality relation. Three adaptation-guided retrieval processes are described. The strong classification in a problem hierarchy is a classical deductive process. It is based on the generality relation between problems which organises the hierarchy. The fuzzy classification is a fuzzification of the strong classification. It is based on a fuzzy generality relation between problems, which can be seen as a non-symmetrical similarity measure. The smooth classification extends the fuzzy classification: it is also based on a similarity or dissimilarity measure but takes into account problem and solution adaptation knowledge. These processes have been successfully implemented in two case-based reasoning systems: Resyn/CBR in the domain of organic synthesis and Kasimir/CBR in the domain of cancer treatment.
https://hal.inria.fr/inria-00107563 Contributor : Publications LoriaConnect in order to contact the contributor Submitted on : Thursday, October 19, 2006 - 9:01:32 AM Last modification on : Wednesday, February 2, 2022 - 3:51:16 PM Long-term archiving on: : Wednesday, March 29, 2017 - 1:23:51 PM
Jean Lieber. Strong, Fuzzy and Smooth Hierarchical Classification for Case-Based Problem Solving. 15th European Conference on Artificial Intelligence - ECAI'02, A. Mille, Jul 2002, Lyon, France, pp.81--85. ⟨inria-00107563⟩
