Cooperative Process Coordination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Julia Bitcheva
  • Fonction : Auteur
  • PersonId : 830716
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Virtual enterprise organization regroups partners distributed in space, time and organization, in order to achieve a common goal. Thus, their business process realization needs the coordination of distributed partners' interactions. This paper presents the synchronization point concept, which provides support for the cooperative process coordination. It provides partners pertinent information about their work progress while maintaining the privacy of information. Moreover, it supports both the long-time transactions and the dynamic process definition as requested for cooperative process management. Finally, its data repository and action manager helps human interactions in cross-organizational applications.
A02-R-158.pdf (490.75 Ko) Télécharger le fichier
inria-00107573 , version 1 (19-10-2006)
  • HAL Id : inria-00107573 , version 1
Julia Bitcheva, Olivier Perrin, Claude Godart. Cooperative Process Coordination. 6th IASTED International Conference on Software Engineering and Applications - SEA'2002, IASTED, Nov 2002, Cambridge, MA, USA, pp.218-240. ⟨inria-00107573⟩
101 Consultations
37 Téléchargements
