Development of Transformation Functions Assisted by a Theorem Prover - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Transformational approach requires to write transformation functions that ensure properties C1 and C2. Proving these conditions on complex typed objects is a serious bottleneck for the application of this approach. We propose to use a theorem prover to assist the development of safe transformation functions. In this paper, we present how we have designed in that way a set of safe transformation functions for an XML typed object.
A02-R-161.pdf (390.5 Ko) Télécharger le fichier
inria-00107574 , version 1 (19-10-2006)
  • HAL Id : inria-00107574 , version 1
Imine Abdessamad, Pascal Molli, Gérald Oster, Michaël Rusinowitch. Development of Transformation Functions Assisted by a Theorem Prover. Fourth International Workshop on Collaborative Editing 2002 - ACM CSCW'2002, 2002, Nouvelle-Orléans, USA, 8 p. ⟨inria-00107574⟩
329 Consultations
134 Téléchargements
