Proving Correctness of Transformation Functions in Real-Time Groupware - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Operational transformation is an approach which allows to build real-time groupware tools. This approach requires correct transformation functions. Proving the correction of these transformation functions is very complex and error prone. In this paper, we show how a theorem prover can address this serious bottleneck. To validate our approach, we have verified the correctness of state-of-art transformation functions defined on Strings with surprising results. Counter-examples provided by the theorem prover have helped us to define new correct transformation functions for Strings.
A03-R-096.pdf (152.25 Ko) Télécharger le fichier
inria-00107652 , version 1 (19-10-2006)
  • HAL Id : inria-00107652 , version 1
Abdessamad Imine, Pascal Molli, Gérald Oster, Michaël Rusinowitch. Proving Correctness of Transformation Functions in Real-Time Groupware. 8th European Conference of Computer-supported Cooperative Work - ECSCW'03, 2003, Helsinki, Finland, 18 p. ⟨inria-00107652⟩
163 Consultations
299 Téléchargements
