Context Driven Access Control to SNMP MIB objects in multi-homed environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Radu State
  • Fonction : Auteur
  • PersonId : 830456
Isabelle Chrisment
The advent of multi-technology networks offering the service continuum over multiple network infrastructures implies new challenges to integrated management. One of these challenges is the auto-configuration of the manage-ment plane needed to allow dynamic relationships among several managers and one management agent. This paper proposes the use of provisional policies in order to dynamically auto-configure the access control part of a management agent. This allows simple management based on agent location and time as well as the cooperative behavior of several managers
Autre [cs.OH]
A03-R-119.pdf (525.13 Ko) Télécharger le fichier
inria-00107661 , version 1 (19-10-2006)
  • HAL Id : inria-00107661 , version 1
Radu State, Olivier Festor, Isabelle Chrisment. Context Driven Access Control to SNMP MIB objects in multi-homed environments. 14 th IEEE International workshop on Distributed Systems: Operations and Management - DSOM'2003, Oct 2003, Heidelberg, Germany, 12 p. ⟨inria-00107661⟩
87 Consultations
65 Téléchargements
