Fast Generation of Random Permutations Via Networks Simulation, Algorithmica, vol.21, issue.1, pp.2-20, 1998. ,
DOI : 10.1007/PL00009206
SSCRAP: An environment for coarse grained algorithms, Fourteenth IASTED International Conference on Parallel and Distributed Computing and Systems, 2002. ,
PRO: a model for parallel resource-optimal computation, 16th Annual International Symposium on High Performance Computing Systems and Applications, pp.106-113, 2002. ,
Randomized fully-scalable BSP techniques for multi-searching and convex hull construction, Proceedings of the eighth annual ACM- SIAM Symposium on Discrete Algorithms, pp.767-776 ,
Generating random permutations in the framework of parallel coarse grained models, Proceedings of OPODIS'2000, pp.1-16, 2000. ,
Randomized permutations in a coarse grained parallel environment, Proceedings of the fifteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '03, 2002. ,
DOI : 10.1145/777412.777454
URL : https://hal.archives-ouvertes.fr/inria-00107672
Fast parallel generation of random permutations, Automata, Languages and Programming Proceedings of the 18th International Colloquium ICALP'91, pp.405-416, 1991. ,
DOI : 10.1007/3-540-54233-7_151
A complexity theory of efficient parallel algorithms, Theoretical Computer Science, vol.71, issue.1, pp.95-132, 1990. ,
DOI : 10.1016/0304-3975(90)90192-K
Virtual Laboratories in Probability and Statistics Finite Sampling Models: The Multivariate Hypergeometric Distribution, 2001. ,
A bridging model for parallel computation, Communications of the ACM, vol.33, issue.8, pp.103-111, 1990. ,
Efficient sampling from continuous and discrete unimodal distributions, 1994. ,
