Support for End User Participation using Replicated Versions and Group Communication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM SIGGROUP Bulletin Année : 1999
Gérôme Canals
  • Fonction : Auteur
  • PersonId : 830484
Pascal Molli
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
We present Tuamotu, a prototype software system for the support of engineering projects distributed over the Internet. This system offers basic services for sharing persistent data between distant activities cooperating in a design project. It is based on replicating versions at each of the participant sites with the use of an atomic multicast mechanism and includes concepts for structuring the cooperation space. The application of these concepts to end-user support in design projects is discussed.
99-R-252.pdf (182.78 Ko) Télécharger le fichier
inria-00107694 , version 1 (19-10-2006)
Gérôme Canals, Pascal Molli, Claude Godart. Support for End User Participation using Replicated Versions and Group Communication. ACM SIGGROUP Bulletin, 1999, 20 (1), pp.5-9. ⟨10.1145/327556.327598⟩. ⟨inria-00107694⟩
87 Consultations
130 Téléchargements
