Comparison of fixed size and variable size packet models in an optical ring network: Algorithms and performances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper, we compare the use of two packets models in slotted optical ring networks: a model where each message has to be routed in consecutive slots, and a model where the slots can be routed independently. We first focus on the algorithmic complexity of the related problems. Then, we give the results we obtain with an OMNET simulator in terms of messages delay and jitter and of communication resources really used at each step.
A03-R-260.pdf (203.41 Ko) Télécharger le fichier
inria-00107697 , version 1 (19-10-2006)
  • HAL Id : inria-00107697 , version 1
Dominique Barth, Johanne Cohen, Lynda Gastal, Thierry Mautor, Stéphane Rousseau. Comparison of fixed size and variable size packet models in an optical ring network: Algorithms and performances. Photonics in Switching - PS'2003, Sep 2003, Versailles, France, pp.89-91. ⟨inria-00107697⟩
246 Consultations
37 Téléchargements
