Text-to-pinyin conversion based on contextual knowledge and D-tree for Mandarin
In this paper we discuss the technologies for text-to-Pinyin conversion based on context knowledge and D-tree for Mandarin Chinese. The local and long-distance context knowledge were considered and exploited. The context knowledge was represented by regular expressions. D-trees were built based on the regular expressions. The experimental results show that the approach using context knowledge and D-tree is an efficient solution to implement Chinese text-to-Pinyin conversion.
