Text-to-pinyin conversion based on contextual knowledge and D-tree for Mandarin - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Sen Zhang
  • Fonction : Auteur
  • PersonId : 836049
Yves Laprie
In this paper we discuss the technologies for text-to-Pinyin conversion based on context knowledge and D-tree for Mandarin Chinese. The local and long-distance context knowledge were considered and exploited. The context knowledge was represented by regular expressions. D-trees were built based on the regular expressions. The experimental results show that the approach using context knowledge and D-tree is an efficient solution to implement Chinese text-to-Pinyin conversion.
Autre [cs.OH]
A03-R-388.pdf (298.31 Ko) Télécharger le fichier
inria-00107717 , version 1 (19-10-2006)
  • HAL Id : inria-00107717 , version 1
Sen Zhang, Yves Laprie. Text-to-pinyin conversion based on contextual knowledge and D-tree for Mandarin. IEEE International Conference on Natural Language Processing and Knowledge Engineering 2003 - NLP-KE'2003, 2003, Beijing, China, 6 p. ⟨inria-00107717⟩
121 Consultations
163 Téléchargements
