Abstract : This report shows examples of simple visualizations of unstructured grids with use of VTK - The Visualization Toolkit. The examples are intended to illustrate few basic visualization techniques of visualization which can be used to visualize results of finite element computations. With each example there is a short description, a diagram showing the organization of a visualization pipeline, a Tcl script and results of running it on sample data.
