High-Accuracy Value-Function Approximation with Neural Networks Applied to the Acrobot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Rémi Coulom
  • Fonction : Auteur
  • PersonId : 836044
Several reinforcement-learning techniques have already been applied to the Acrobot control problem, using linear function approximators to estimate the value function. In this paper, we present experimental results obtained by using a feedforward neural network instead. The learning algorithm used was model-based continuous TD(lambda). It generated an efficient controller, producing a high-accuracy state-value function. A striking feature of this value function is a very sharp 4-dimensional ridge that is extremely hard to evaluate with linear parametric approximators. From a broader point of view, this experimental success demonstrates some of the qualities of feedforward neural networks in comparison with linear approximators in reinforcement learning.
A04-R-082.pdf (124.25 Ko) Télécharger le fichier
inria-00107776 , version 1 (19-10-2006)
  • HAL Id : inria-00107776 , version 1
Rémi Coulom. High-Accuracy Value-Function Approximation with Neural Networks Applied to the Acrobot. 12th European Symposium on Artificial Neural Networks - ESANN'2004, Michel Verleysen, 2004, Bruges, Belgique, pp.7-12. ⟨inria-00107776⟩
130 Consultations
337 Téléchargements
