A Java based Implementation of a Network Level Information Model for the ATM / Frame Relay Interconnection
Radu State 1 Emmanuel Nataf 1 Olivier Festor 1
1 RESEDAS - Software Tools for Telecommunications and Distributed Systems
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In this presentation, we illustrate the use of the Java technology to implement a network information model which captures the essence of the ATM and Frame Relay Interconnection. We show how the TMN concepts stay valid and how the existing and extended information models can be reused and implemented according to the TMN principles in a full Java environment.
Type de document :
Communication dans un congrès
2000 IEEE/IFIP Network Operations & Management, Apr 2000, none, 2 p, 2000
Liste complète des métadonnées
https://hal.inria.fr/inria-00107843
Contributeur : Publications Loria <>
Soumis le : jeudi 19 octobre 2006 - 09:11:32
Dernière modification le : lundi 12 février 2018 - 11:52:01
Document(s) archivé(s) le : mercredi 29 mars 2017 - 12:58:31
  • HAL Id : inria-00107843, version 1
Collections
Citation
Radu State, Emmanuel Nataf, Olivier Festor. A Java based Implementation of a Network Level Information Model for the ATM / Frame Relay Interconnection. 2000 IEEE/IFIP Network Operations & Management, Apr 2000, none, 2 p, 2000. 〈inria-00107843〉
Métriques
Consultations de la notice
185
Téléchargements de fichiers
41
